Working Key's who need them
Username: Ke5aqn
Shawnee, OK USA
Post Number: 267
Dish
7B A3 12 F7 A3 07 68 38
87 2D E3 D5 A1 09 51 11
C9 3E 92 9C 14 C0 41 41
05 7A FC 35 A4 4D 0E 8A
bev
DE CF 2A 17 99 7F 69 74
46 35 E6 28 75 24 F4 C0
01 63 FF 4D 83 1A AA 8B
BC 28 6B 09 BF DF 0E 42
Username: Jedimastermopar
Post Number: 17
I had 46 35 e6 28 52 f4 c0
Username: Ke5aqn
Shawnee, OK USA
Post Number: 269
ya it just takes one # off to make it not work..
Now with that vewsat after you get the key in right autoroll will do its job and keep it working....I got my viewsat about 5 weeks ago and put in the #'s once and its worked every day.
Post Number: 18
did you do a blind scan or autscan?
Username: Ke5aqn
Shawnee, OK USA
Post Number: 270
you should delete all your channels and blind scan the sat's. I do mine once a week or so did it last night as a matter of fact.
Post Number: 19
what di you set the freq number at? I set it at 6?
Post Number: 20
and is there an easy way to get rid of the extra channels?
Username: Ke5aqn
Shawnee, OK USA
Post Number: 273
go to edit channels and delete all before you da a blind scan.
What frequency do mean? LNB? for what sat?
6 would be way way to low LoL
Post Number: 21
When your in the blind scan you have onl 3 options one of whitch is 5 6 10 15 etc
Username: Ke5aqn
Shawnee, OK USA
Post Number: 274
you have lost me you need to find a "how to" for your receiver. Mine is a platinum and it has no options on blind scanning......you just blind scan the sat you selected
Post Number: 22
the manual that came with mine deosn't give any detail other than the option is there. :-)
Username: Ke5aqn
Shawnee, OK USA
Post Number: 275
ok ok ok do a factory reset then do this::
All the credit goes to gugi47 for this.
Viewsat 2000 Ultra Setup Guide
If you follow this steps, your up and running in less than 5 min.
- Instal you STB and connect all the cables
- Turn the power ON from the back switch
- Press Menu key
- Select Installation and press OK
- Select Antenna Setup and press OK
- Select your Sat.
- Here if you have a DISEqC switch enter the port #, Motor or Legacy SW
- No LNB Type need to select (from new, you have only two selection Standard and Universal) The STB will select your LNB Automatic
- Press Exit and select Yes for saving the settings
- Your back to Antenna Setup screen
- Here you have Three choises:
- 1 Channel Scan
- 2 Auto Scan
- 3 Blind Scan
- I try all, but the best its Auto Scan
- Press OK
- You are in the Auto Scan window and you see the Bird(Sat.) you selected and in the top of your screen are three options:
- 1 Search option
- 2 Network search
- 3 Scan Start
- You don't change nothing, go down and select Scan Start and press OK
- You do this for all the Birds (Sat.) you have
- Now its time to dowload you BIN
- Insert the Memory Stick in your PC and transfer the bin in. Than insert in your STB and in the Main Menu select System information and press OK
- Select Receiver Upgrade and press OK
- Go down to the bottom of the window, select USB and press OK
- A new window its open with some Corean files, years, etc.
- In the bottom of the window its your bin select and press OK
- VERRY IMPORTANT. DON'T TURN THE POWER OFF
- After you load the bin, the STB will reboot automatic
- Wait for Autoroll and wach TV
- GOOD LUCK.
