Sonicview 4000 usb receiver is out. Sonicview 4000 USB Wholesale, Forum Bin Sonicview 4000 USB Receiver Brand New Sonicview 4000 USB 2.0 allows you to get use of flash rom USB drives and update your sonicview 4000 receiver by them. This makes the receiver a lot easier to update and makes it more user friendly. Sonicview 4000 is like the Cool-sat 7000 that also has a USB drive and allows you to plug in hard-drives and make it a DVR. Sonicview 4000 is also like the Viewsat Ultra. Sonicview receivers all have blind power scan that allows you to directly connect to satellites in the sky then search for channels using the DVB MPEG2 stander it can then give you all the channels for free. This works for KU-Band or C-Band satellite dish systems, does not work for DirecTV or dish network. For motr ingo on Sonicview 4000 USB then read more on our website or find other links on our website for all your info on Sonicview 4000USB.
