thats right. after the 27th comp i am gonna get a single btl 18 dual 1ohm. ima build a killer box for that and see whats up. i can do 6 cuft box for the btl 18 so i have room for a 100sq inch slot port. muhahahahahaha.
since it will be dual 1ohm, i can run 5000wrms to that single 18. it will be insane.
btw.....no my current btls won't be for sale. i will hang on to these for a spl car i am going to build with a honda civic.
You rich bastard! And you wouldn't even give me one of your BTL's, even after I wrote a tight ass rap about you and your system.... Let me know how Hussein, Osama and satan are when you send me a letter from hell!
lol. Chad im gonna pickup another set of utopia and do some kick panels up front for them after i get everything else goin. what kind of power are you giving them? I will be giving them 90RMS from a kicker amp. Prolly a little more
right now i have my focals running off of my audiocontrol 6xs xover with a jl audio 450/4. i am not using the one that came with the speakers. it sounds so much better this way.
150wrms x 2 for the mid 75wrms x 2 for the tweeters.
thats a grand idea instead of making 2 subs with less than good volume use 1 killer sub instead
here is a another idea y not just run a single 15" which u already own in a better cuft box say 5cuft - all it will cost u to find out how good is just the box materials cost & ucan even still use ur 2 wcc amps on it with 3400wrms total .....
i was thinking about that rovin but my sub is dual 2 ohm so i won't be able to get the full 2500wrms from my amps.
i like the sound right now alot. don't get me wrong. its the port area i am after. i can't get 100sq inches of slot port with 2 15s. i want a spl setup. the 18 will be a pure spl. with 46hz tuning. lol.
