alright well my friend said he is gettin 2 12" L7's instead powered by some two channel hifonics amp....what would a good setup be that around $1000 and not too big cause i want it to be able to fit in my next car so prolly like 1 15" or 12's or sumthing and i dont want to have to upgrade my electrical..any suggestion
you have a lot of options, the no new electrical upgrades is holding you back.
sub could be:
dd2512 dd3512 fi q fi ssd tc-1000 tc-2000 audioque sd audioque sd2.5
amp can be determind after the sub is chosen...but most likely to run it off the stock alt (guessing is 100A) id go no more than 1500rms...or even that high, i wouldnt go much over 1200-1300rms.
damn i bought a used jbl amp for 200, 15" Q for 270, box-hand built 20, 4 guage wire for $90, eclipse cd2000 HU on ebay for 60, stinger trunk batt for 100, stinger cap for 100, 0/1 big three 25, thats 775. if you dont want to buy a used amp that still leaves you a ton for the amp. btw, its loud.
i was thinkin a Q on an ed nine.1. Would that get louder than the 2 10" l7's cause they are gunna be run off a two channel hifonics amp (dont know which one) probably underpowered and in a sealed box
3515 i think is about 400 give or take 50. talk to kevin at low-hz for them. he sells dd now. i almost bought the 2512 for about 250 from him. great guy to work with
the 3515 would be louder most likely. its rms is 1200 but can take more. if u get the 3515, id put around 1500 rms or even more. i dont think your stock alt can handle that much power. the q would fit right in with your stock alt. id go with a q and the ed nine but its your call...or your friends
