Plz. help fix receiver that only works with the W or local channels.
Username: Syla12
Hey guys can someone please lead to how i can fix an old receiver i have. This receiver is a PanTec 2500 Ultra. The w channels or the local channels work but the rest don't. I remember every one had this problem like 7 months ago but there was a cure or something ( i bought a new one)anyway can someone plz. tell me how to fix it if there is a way to fix it.
thanx so much.
Username: Nikk
Post Number: 830
You need to get the latest bin for the pansat 2500 since pantec is a pansat clone, after that you must be sure you have everything configured properly, then delete all of your channels, do a blindscan and then get the latest keys and input them manually....you will need a RS232 "straight" cable to plug your PC to your pantec...
Go to al7bar.com you must register and they have a good guide to do all of what you want, ypu just need to read a little bit...
Username: Syla12
i already put in the codes manually do i still need to put in the bin or can i just factory reset and it should work?
thanx. alot
Username: Nikk
Post Number: 831
If you do a factory reset you have to configure again everything, I don't recommend to do that, once you have everything configured it is just matter of entering the keys.
You need to check which bin the receiver has, go to menu, then to system information and it will tell you the bin, you need the 286T bin....if the receiver doesn't has that bin, then go to al7bar and get it, after that download it to the receiver...
Username: Brucester
Post Number: 134
Clone safe 2500 autoroll bug fix
287t working good on my clone
Username: Syla12
which loader do u recommend i get and can you plz. tell me the bin.
thanx again
Username: Prfrmnj
Post Number: 1153
Use the BL 1.4 Loader
Username: Tetuscosmicus
Post Number: 551
===HEY GUYS LOOK===
www.expressfr.com ====that,s good
Username: Johnner
Miami, Florida
Post Number: 1032
BL 1.4
http://www.dssrookie.com/forums/attachment.php?attachmentid=57911&d=1167856294
Post Number: 552
===GUYS LOOK====
IS FOR BINS FOUR CLONE 2500 FORTEC (PANSAT) http://www.z21.zupload.com/download.php?file=getfile&filepath=21480
click in donwload file end redy
Post Number: 553
===http://z21.zupload.com/download.php?file=getfile&filepath=21480
click en donwload file end redy
Username: Nydas
Post Number: 1175
T o summarise, you need
1. a straight RS232 DB9 F/F cable. (Radio Shack)
2. a software peice called winzip.exe. (http://www.totalfta.com
http://www.future-fta.info
http://www.dssevolution.com
