Sealing off the trunk
Username: Goodie_goop
Midland, Texas U.S.
Post Number: 109
im putting my system in the back and i have the seats out, but i need to seal the trunk off so no air gets through. im planning on using a bored and some sound deadner but i dont know how much im gunna need to order?
have any of you done an install like this?
chad lee i think you did...how much did you use?
also whats good but cheap on ebay or sumthin? i never bout sound deadner before
Username: Teddy21
Ann Arbor, MI USA
Post Number: 385
edead
Midland, Texas U.S.
Post Number: 110
bump on how much i should order
Username: Bernymac
Cambodian
Post Number: 1696
measure it.....
Midland, Texas U.S.
Post Number: 111
...hmm
good call
just wanderin what anyone else did. is one layer good? am i gonna need to put it anywhere else in the car?
Username: Frkkevin
Post Number: 2575
just cut a piece of MDF to fit an use some weather stripping on where it meets the surfaces.
should be fine.. if you want cheap deadener go to lowes and get a roll of peal-n-seal for 15 bucks
Fi Audio BTL
Post Number: 8941
damn i wish i took some pics before i put my box in.
what i did was i cut a piece of mdf in the shape of the back of the backseat. that way it fits right in there. then i deadend the backside of the wood. then i bolted down to the metal bar that goes across the top. for the bottome, i bolted down to the platform where my box sits. i put edead on the corner where the back and the bottom meat.
its nice and air tight now and the bass is so much more responsive and loud in my cabin now. i love it.
Midland, Texas U.S.
Post Number: 112
sweet thanks
ill prolly order some of that edead off ebay, it doesnt look too expensive
Username: Bernymac
Cambodian
Post Number: 1711
order it off of elemental designs website. use their coupon w/e to get it at a lower price. just ask someone else, I dont have that info. sorry.
Username: Johnfiac
IL Afghanistan,...
Post Number: 958
i just payed 70$ shipped for 60sq. Ft. from ebay...it comes with a FREE DYNAMAT ROLLER!!!!! WOOOHOOOOO... most likly wont even use it..? lmao
Username: Safe_cracker
Chicago, IL US
Post Number: 2327
60 sq feet isn't even enough for a trunk! I bought that bulk roll from e-bay the BIG one and it barely covered my trunk, once..Polo.
Username: Ctmike
Ct.
Post Number: 2891
i'd plan on buying at least 150sqft.+ if doing the entire car if i was you. depends on how many layers you want. i used a little over 200sqft. on just one car awile back.
