Subwoofer ohms load question
Username: Spandmh1
Tunnel hill, Ga Usa
Post Number: 110
what that website you go to that shows u the different ohm loads? u know, the one that shows u how to hook the subs up?
Username: Nyyfan13
Fi SSD USA
Post Number: 2303
http://www.the12volt.com/caraudio/woofer_configurations.asp
there u go sir
Username: Spandmh1
Tunnel hill, Ga Usa
Post Number: 111
gracias bro
Username: Nyyfan13
Fi SSD USA
Post Number: 2304
not a problem
question for you or anyone
whats the site that designs boxes for you? or any box maker thing. im bored and want fool around with one and see what happens.lol
Username: Brayden
question up.
for the ohm loads do you need teh wiring that is rated for that many ohms. like if your gonna wire it for a 2 ohm load do you need 2 ohm wiring? just thought id check...
