I am about to buy a Massive Audio P3000.1. I need to know if anyone has ever used one. The amp measures 38 inches on the Massive Website. On Amp Guts it says it requires a 200 amp external fuse. That seems somewhat small. I hope its not way underrated. Massive says it does 3000w RMS @ 2 ohms at 14.4 volts. Has anyone actually used one? I need to know fast...
you actually need 14v+ like it says to get the 3000rms so it is accuratly rated. really i dont think your going to notice any difference from this and if you had your orion2500d at .5ohm
Very nice amps, they push my hd3's really nicely at 2k total. 1k to each sub. Shipping one amp out bc it was broken during shipping. But a great amp. I also like that you can do 1500rms x 2 at 1ohm.
