Marantz PM 94
Username: Shiggler
I have just purchased a Marantz PM 94 amp. I'm aware these run hot and have noticed that the right heat sink (behind the vol pot) emits significantly less heat than the left heat sink, almost to the point of saying that the right hand side of the amp (looking face on) is only luke-warm to touch, not hot like the left side. Is this normal operation for this amp? If not, what may be casuing this to happen and suggested remedies? Many thanks.
Username: Nuck
Post Number: 5193
Hi Tim, and welcome.
Try switching the speaker leads left to right on the amp and try for a while.
The sinks may not be symmetrical, as well.(unlikely, but possible).
Username: Jan_b_vigne
Dallas, TX
Post Number: 9611
The amp probably isn't symmetrical in layout. One side probably has the power supply and the other the output devices. Most amps do not have the left channel tansistors on one side and the right channel outputs on the other. It is far easier and much more efficient to design all circuits to run in particular areas of the chassis. If you'd like, just remove the top cover plate (with the amp unplugged from the AC outlet) and check where the output transistors sit. That's the side that will get warmer than the power supply side.
Dallas, TX
Post Number: 9616
Just as a word of advice; not all "heat sinks" do anything. More than one fin on an amplifier has been placed there by the marketing department rather than the design team. Kind of like '58 Cadillacs.
