Post pics of remote controlled cars
Www.15inchwangers.com
Post Number: 9414
let me see what kinda remote controlled cars everyone has.
Nj US
Post Number: 2789
I know, you've seen it.Upload
Nj US
Post Number: 2790
I also have a PT cruiser, PU truck, and two boats.
Username: Project6
Post Number: 12451
Nice. I used to be heavy into RC, back in the day. Tamiya and Kyosho were my toys.
Post Number: 9433
is that gas powered?
Username: Basshead86
FTW
Post Number: 9843
how about a pic of my xbox 360?? lol
Username: Arande2
400dB could probably d..., SouthWest Mi... Too Many DBs...
Post Number: 820
A nitro powered Xbox 360!
Username: Rideredder
Cornell, IL USA
Post Number: 701
It's a little dirty, but dirt is all that I've had it on.
Cornell, IL USA
Post Number: 702
BTW, that car is a Traxxas Rustler .15.
Www.15inchwangers.comFI Audio BTL
Post Number: 9518
nice mark. do you use that de walt to start the car?
my friend but a monster truck after i told him not to. it is so slow. i told him to get a light truck or a buggy. ima get a buggy.
Username: Arande2
Post Number: 908
Yeah, this is my RC Truck!
Yeah that's my aunt who gave it to me!
She didn't tell me the control center would be so hard to operate!
I want an RC truck like that
Username: Leew
XXXX!!WWWW, Yokosuka, ... Holla Back Y...
Post Number: 1321
Andre!
My is better!
and I can sale it to you!
Username: Arande2
Post Number: 913
How much?!!!?!?
Username: Arande2
Post Number: 914
What kinda engine you got on that thing?
Username: Leew
Post Number: 1322
1600 H.p. electro disel.
Username: Arande2
Post Number: 916
I like mine better! My aunt had it upgraded to a octo engine design with each engine being 169.5L 16 cylinder 3300 hp (2,460 kW)
equalling 1356L 128 cylinder 26400 hp (19680 kW) before the Tornado + Velocity Superchargers and high capacity/velocity nitro feeds which kick the peak HP to a total of 100 centillion (only) when using the MAX nitro feed of 100 TeraLiters/Sec (uses all the nitro within 20 hours).
Sometimes I rev the engine system to full power and I've modified the pipes to twice the diameter in order to increase maximum horsepower so when I take off at lower speeds I speed up just enough to keep a wheelie until I reach Mach 20 which then slow down the accelerate so I stay on the ground until I reach Mach 100, then I take advantage of the diameter of the pipes and rev the engine to MAX TURBO TORNADO where I then pop a wheelie and take off until I reach the max speed (before nitro) mach 5x10^10 where I then engage the Stupid-high velocity nitro pumps then reve the nitro in like crazy which in turn pushes the engines to that extreme HP level which makes it again pop a wheelie and reaches the speed of light, then breaks it. This creates a superelectromagnetic boom which blinds anyone in the path of the boom. Now I centuple the feed through of the tanks and dump all the nitro in at once pushing the engine so hard it converts the energy to motion at 1 centillion^1 centillion% efficiency pushing the vehicle to Warp 5X10^100centillion^100centillion^100centillion causing the vehicle to turn into a time machine which takes me back into hyperspace and I enter a black hole at such high velocity that I break through the wormhole and find myself at the time of the Dinosaurs where I bring them all back to present time and we learn the cure for cancer and world peace is solved + I get an infinite supply of money.
Thank you my aunt!
Username: Leew
Post Number: 1325
You have to upgrade intake system and install ceramic manifold, then you will be totally ok!
Listen,I liked you! Next time lets smoke the weed together...
Username: Arande2
Post Number: 919
FTW
Post Number: 9877
hahahahahahahahahahaha
you 2 are funny as hell
