alright I got a 2005 roush focus and I'm getting new system total of 6000rms (massive 3000.1s) and I need to know exactly what to get for electrical thanks
NATE TOLD ME THAT A SINGLE 300 AMP ALTERNATOR CAN KEEP UP WITH THAT POWER AS LONG AS U GOT SOME GOOD BACK UP (BATTERIES), A DUAL ALTERNATOR KIT WILL COST YOU AROUND 900 EASILY WITH 200 AMP ALT, BUT FOR THE TYPE OF YOU CAR DUAL KIT ALT ITS NOT AVAILABLE IF U CAN FIND A 300 AMP GO FOR IT, THE 3 KINETICS WILL MAKE SOME GOOD STUFF BUT WILL NOT HELP YOU ABOUT YOUR VOLTAGE DROPS, NO BATTERY ISOLATOR IT WIL MAKE IT WORSE BUT A CAP WILL ABSOLUTELY HELP ALOT IN THIS SITUATION, A KINETIK HC600 NEAR THE AMPS WILL HELP ALOT. MAKE SURE U MAKE A RUN FOR - AND + AND AT LEAST LIKE 2 RUNS OF KINETIK COLOSUS CABLE FOR EACH - AND POS,
ONLY IN CHARGING UPGRADES WILL BE MORE EXPENSIVE AS THE TWO AMPS ALONE WILL RUN ABOUT 900+ IF U GET THE GOOD STUFFA SINGLE KINETIK HC2400 ITS ABOUT 300 DOLLARS ON EBAY.
