Amps on Box??
Username: Skibum12189
Post Number: 43
How bad would it be to mount my two kicker amps on top of my triple sub box. A kid told me elemental designs covers it under warranties. The amps are brand new and its three 350-400 watt rms sealed box subs.....
Tell me what you think bc itd look 100x cooler in my opinion
Username: Nyyfan13
Fi SSD USA
Post Number: 2084
nah dont mount on the box, put them beside the box or in front of but not on. could damage the amp
Post Number: 45
what if i built an extra piece on top to mount em on, like a regular rectangle box, but then like a 45 degree angle piece to mount em angled to the rear of the car?
Username: Nyyfan13
Fi SSD USA
Post Number: 2086
thatll help, just dont mount them directly on the box cause it can damage them. but if you add more of a "buffer zone" it'll be better. ive heard, i dont know this for a fact, but if you can get rubber and put it under the amp or something it will reduce the vibrations coming onto the amp. i dont know if this is true or not but it does sound kind of logical. someone else will have to tell you about that tho.
Username: Logan__tille
[:-]15 RE XXX[:-]
Post Number: 4378
could you put the amp somewhere else?
Username: Safe_cracker
Chicago, IL US
Post Number: 2321
An amp needs a solid mount. The reason mounting an amp to a box is a bad idea is because the flex of the panels. This can cause broken solder joints and other electrical component in the amp to fail. Think about this, all it takes if for ONE single leg on an output fet to break and you will lose the rest of your amp. The output stages fail in a cascading effect and this will be costly. Make a piece of MDF the sidze of the amp you want to mount. Find a spot closest to any internal bracing, bolting the panel down first then the amp to it. If at all possible, mount it to the top or to a whole different place. Keep us posted... Polo.. :-)
PS-Adding a layer of rubber will not help with frlex, maybe with vibes a bit but remember most vibration we deal with it airborn, so the rubber may even amplify this effect.
Post Number: 46
What if i built my box and everything with like a rectangle and then put like a big amp rack on top and put dynamat or some edead under the carpet and then screwed my amps onto that mdf. Would that sufficiently stop the flex or is it still not worth the risk
Username: Jeromebaker
Post Number: 44
If you use good quality thick fiber board you should be fine. I've done it with every amp I've ever owned 6 years and going and none have fried/broke because of it. Your amp is getting almost as much vibration if it's close to the box anyway.
I've heard horror stories of parts being rattled loose on a box some guy built out of an old wal-mart dresser, but I haven't had problems.
Just don't go mounting it to some rice-board box and you should be fine. The key is to use good wood. Mount an extra board if you want to protect it further.
Username: Nyyfan13
Fi SSD USA
Post Number: 2131
"PS-Adding a layer of rubber will not help with frlex, maybe with vibes a bit but remember most vibration we deal with it airborn, so the rubber may even amplify this effect."
i lose, someone suggested it to someone else and i read it and it souded logical but polo is a genius. thanks for clearing that up for me polo
