One satellitte hooked to 4 recievers
Username: Peruil
i have one dish recieving 110 and 119 how do i split to 2 other tvs for a totalof 4 recievers a slitter does not work help please
Username: Poser
FTAPlayGround.NETFTAPlayGroun...
Post Number: 90
you need to have dual lnbs, these are standard lnbs with 2 outputs, then u need to buy two switches called "Multi switch" and 4 "diseqc" switches
here's a pic of multi switch:
http://img176.imageshack.us/img176/7492/multiswitch2bigxt9.gif
u need to connect both outputs of ur 110 lnb to the first multiswitch and both outputs of 119 lnb to the 2nd one.
then connect the first out put of each multi switch to a port of a diseqc switch, now you connect the out put of the diseqc switch to ur first receiver,
do this for all 4 receivers and adjust ur dish settings,
good luck,
Username: Satscanner
Beaversbush, Sportsmans P... Great White ...
Post Number: 656
A dp 34 multiswitch.Two switches and you can run 8 receivers,and add a third sat.dp44 and 4sats.
Post Number: 657
Poser,He has one dish,and wants 4 receivers, single lnb and a dp switch.If the lnb's are dual two switches and that will run 8 receivers.dp34=3sats and dp44=4sats
Username: Prfrmnj
Post Number: 1138
Terry - All you really need is to get yourself a DishPro (Quad) Fat head LNB. It has 4 outputs/outlets. One for each receiver. Simplest thing to do. No need for switches unless you intend to add more sats or more then 4 receivers.
Post Number: 660
PRFRMNJ,didn't even think of that route,But don't some receivers have performance issues with it?Especially when multiple receivers are used.
Username: Prfrmnj
Post Number: 1141
Sat - The issue is when you use a DishProPlus. That LNB is not FTA Friendly. This is one of the most easy to use LNBs. I actually have one connected to 4 (stbs) One in the Living Room Viewsat Ext/ One bedroom Viewsat Platinum; Fortec and Pansat in the other two bedrooms. Never had a problem.
Username: Maximus06
Post Number: 46
I have a modified quad pro and use two disq one for each receiver. one recvr tend to freeze then TP update and sometimes out of service when both TV are on Please help I have old multi switch please show me how to set it up???
Username: Prfrmnj
Post Number: 1142
Why would you use a disecq if you have a dishpro quad. you don't need a switch. This LNB has a buildt in switch. Take one coax and go directly into your STB.
Username: Lksuxit
Post Number: 82
Hey LK
Username: Backdoor
Post Number: 13
my pansat is down can u help me with new keys ple.
Username: Guest6306
Pickerington, Ohio USA
PRFRMNJ-
Won't you need a DisEQ switch if you are connecting
another sat- say 61.5 legacy LNB?
Username: Lklives
Post Number: 6875
Guest...U need to explain what dishes, LNB's, sats,receivers, settings ect...we don't need to be playing guessing games all day..
Username: Guest6306
LK-
DishPro Quad LNB, Dish 300 Legacy LNB, Fortec Ultra.
To connect these you will need DisEQ switch, right?
Username: Lklives
Post Number: 6877
yes, if ONLY 1 receiver and since the 300 is a legacy and a single, and NOT a dual legacy or DP..
Username: Backdoor
Post Number: 14
hi can i use my old bin & the new keys on my panset 3500sd i belive the bin is 03-oct-06 and if so what are the new keys
thanks
Username: Shn
new bin for viewsat extreme
Username: Lklives
Post Number: 6905
Nope...still 1213 or 1220 for VS Extreme...those bins are fine..
Username: Rogybe
Post Number: 16
PRFRMNJ, Terry - All you really need is to get yourself a Dish Pro (Quad) Fat head LNB. It has 4 outputs/outlets. One for each receiver. Simplest thing to do. No need for switches unless you intend to add more sats or more then 4 receivers.
PRFRMNJ,
In tread 119 HARD TO GET, I have explained about DP Twin and problems scanning with Pansat 2700, I am sure that there would be a problem with Quad DP LNBF also, if someone has experienced that problem please let us know what you think and is there solution to this problem, My problem is that only signal from one Satellite gets scanned and what ever you would try to get the other sat, it gets the same one and you get double channels double numbers. But when I use 2 LNBF's and DiseqC switch I can scan both satellites just to be sure I disconnect one cable just to be sure not to scan wrong channels.
Username: Lklives
Post Number: 6912
The DP twin is the easiest LNB to use...just aim it and scan!...both sats ( either 82-91 or 110-119) on 1 cable...the 2 outputs are ONLY for 2 receivers! ...same thing for the DP quad, exceptt 4 outputs for 4 receivers
If U only get 1 satellite after scanning BOTH satellites, and get duplicates, then U have either..
1...bad LNB
2...bad cable
3...bad dish alignment
4...incorrect antenna/dish settings in receiver
BUT I will say 99.9% that its your Dish alignment
Its that simple!
