NEW BEV KEYS
Username: Dirkdeagle
Post Number: 20
we've got the latest new BEV keys for download as well as all the latest fta files and software for all major brands of fta receivers such as pansat and more. at http://www.n2news.com
Username: Lklives
Post Number: 6649
Bev Provider 0901: Last Updated (Dec27 5:00pm EST)
Key0: BC C2 5F 1E C8 4A FF 41 C4 68 4D DB DB 0D 9B DE
Key1: 3A 99 4D B9 87 6C ED 6F 83 34 68 6D CC DB 5E EC (Active)
Username: Lklives
Post Number: 6652
Nagra2 Keys
Dish Provider 0101: Last Updated (Dec27 4:30pm EST)
Key0: 50 45 2E 55 5F C9 46 D7 48 DE 19 8C BE 2C 50 90
Key1: F5 08 EC 80 E6 EF 1E 6F B7 74 BF 73 69 7A AF F5 (Active)
Bev Provider 0901: Last Updated (Dec27 4:30pm EST)
Username: Mcrabbycabby
Wpg, Man Canada
hello i have a pansat2700 clone and im having trouble picking up bell i blind scan the nimiq1.3 and still not getting anything ive checked the keys their right but i just cant get nothing any help or suggestions thank you very much.
Username: Lklives
Post Number: 6781
could be a hundred things...hardware or software related..read a Pansat manual and dish pointing tips...at dsscommunity.c*om...Bev is done the EXACT same way as DN, except the keys and aiming the dish..so if U have/had DN, then U know the answer is in the keys or alignment..
Wpg, Man Canada
Post Number: 7
thank you lk i know my dish is pointing proper i had my rom card on it and just got my fta back ill get my buddy to check it i was just hoping it was something easy i was missing.
Username: Lklives
Post Number: 6785
If U KNOW 100%,
the dish has NOT moved slightly by wind or weather elements..
or cable not eaten by a squirel or bird, or is weather beaten...
the connections are NOT loose or corroded
and your switch has NOT just gone bad (because they are so cheap and cheaply made) and is not weatherproofed...
that U have rechecked your antenna/dish receiver settings and ARE in fact currently correct for Bev and/or DN sats and LNB's..
Then U may want to upload the factory bin, do a new scan, load the latest bin, recheck the antenna/dish settings again, wait and let keys autoroll or manually input them, and reboot the receiver..
Username: Lklives
Post Number: 6816
Bev Provider 0901: Last Updated (Jan02 4:30pm EST)
Key0: 6A EC 7C 59 4D C5 8C 79 EF 61 D0 0C 87 FF 87 3B
Key1: 0D 68 3A 7D 4F CA 26 E2 4A DC 49 B0 25 18 91 05 (Active)
Username: Canndy
Post Number: 48
Sorry LK, those are old BEV Keys...
Bev Keys: Last: Jan 3 10:50
Aux 86: C6 D6 A5 73 6D DA EB 14 AE 04 5B D5 84 01 67 36
Aux 96: 0D 68 3A 7D 4F CA 26 E2 4A DC 49 B0 25 18 91 05
www.LiveFTA.com for the latest keys.
Username: Lklives
Post Number: 6822
they weren't OLD when I posted them!...your keys will be old, when they change again!
Username: Poser
FTAPlayGround.NETFTAPlayGroun...
Post Number: 73
LMAO changed Wed Jan 3 10:34:23 2007
Username: Lklives
Post Number: 6827
Keys change at different times and different speeds on different receivers at different locations...but usually all within 1 hour...especially when using autoroll..and if U log the stream, then U can see it coming before they are ACTIVE!
Username: Poser
Post Number: 75
yeah I was confirming that when u posted them they were not changed yet, my pot is c/p from ftaplayground.net, they get their keys live from a logger I think, it's not like a thread posted like other sites,
Username: Lklives
Post Number: 6837
All sites and key finder utility programs get their keys from a logger...I myself am a keymaster..
Username: Canndy
Post Number: 53
Bev Keys: Last: Jan 4 14:20
Aux 96: CD 5B A1 99 F7 AC BC 44 4F 15 05 D6 C4 E2 75 23
Username: Charmed
Can someone tell me how to go step by step to find Nagra2 Keys? Bev Provider 0901 last update? Dish Provider 0101? So I can do this myself! Thankyou,
Username: Canndy
Post Number: 85
[link removed]
