New member Username: Sermes22Post Number: 1 Registered: Jan-07 | Can somebody help me. A few days ago i enetered the BIOS menu and changed accidentally my Bios password. Now when i turn on my laptop i cannot use it i have "power on password" on my screen. please help me to solve this problem. |
Platinum Member Username: Project6Post Number: 12409 Registered: Dec-03 | You accidentally changed the password? How many confirmation prompts did you go through to actually change the password? |
Silver Member Username: Arande2400dB could probably d..., SouthWest Mi... Too Many DBs... Post Number: 741 Registered: Dec-06 | I beleive he went through 1,419,183 prompts Oh sweet the power just blinked on! Let's see if it stays... |
New member Username: Sermes22Post Number: 2 Registered: Jan-07 | Sorry if i didn't explain myself well. I changed it by myself but forgot to write the new one, and now i don't remember. |
Gold Member Username: LeewXXXX!!WWWW, Yokosuka, ... Holla Back Y... Post Number: 1252 Registered: Jan-06 | well try this method: cut the power,unplug everything,get to the motherboard and remove small battery (circle one,looks like 25 cent).Wait one hour then put everything back.It should work 99%!!! if not then you need to get a bios cracker (a small "hacka" programm ).So do it,don't sit ...go go go ! |
Gold Member Username: LeewXXXX!!WWWW, Yokosuka, ... Holla Back Y... Post Number: 1253 Registered: Jan-06 | BTW, this is the list of the bios pass. killers: BIOS / CMOS Tools: CMOS 0.93 CMOS Save / Restore Tool BIOS Cracker 4.8 BIOS password remover (cmospwd) BIOS Cracker 1.4 BIOS password remover (cmospwc) BIOS Utility 1.35.0 BIOS Informations, password, beep codes and more. BIOS 3.20 a powerfull utility for bios and cmos You can find it on a web! (google it) |
New member Username: Sermes22Post Number: 3 Registered: Jan-07 | Thank you very much for your help. I tried to remove the battery unsuccessfully. How can i use one of the programs from above when i do not have any boot system. |
Gold Member Username: LeewXXXX!!WWWW, Yokosuka, ... Holla Back Y... Post Number: 1269 Registered: Jan-06 | well...U have to read here:Click ! |
