i scanned echo8 all the channels came down but the ppv pansat2700 using 288 bin with the keys manually entered and only ppv did not came down after the scan any idea . ? thanx
cartier, install bin 290...it fixes autoroll, clock works perfect now, you don't even have to set the time anymore it does it by itself...picture quality is better to...
Download at Future-fta.info or any other site that has a files section
thanx fta i have couple of box that i test all the times. just a friend asked me to answer his problem which i dont understand why it happen to him that he scan the 110 and he can not get ppv? so i tought maybe it's something weired and i can shre with you guys . thanx fta. btw my favorite is viewsat
FTA stbs don't always scan perfectly, sometimes they get stuck on a percentage and don't get all channels...if you rescan you will get all channels...that is if you have you stb setup right with the antenna...install the latest bin anyway to have the new features...
cartier always has problems with these simple things..then screams at everybody else like they're stupid...I have banned him once already for his attitude caused by his own errors..
