Username: Zbate Sadd,
Texas
United states
Post Number: 1 Registered: Jan-07
Wednesday, January 03, 2007 - 20:03 GMT i have 2 l5 12's and i'm not sure what amp to go with
Username: Blainew Alpine type S 6.5 inch...
Post Number: 2037 Registered: Nov-05
Wednesday, January 03, 2007 - 22:28 GMT the 1000.1 will do more than 1000 watts... i personally would get the 1500.1, but that will be overpowering those subs if u arent careful. if u wanna be on the safe side.... and save some money get the 1000.1
Post Number: 2038 Registered: Nov-05
Thursday, January 04, 2007 - 02:56 GMT i actually think the 1000.1 will be good....i think itll do 1200 rms
Username: Bestmankind Fi Audio BTL
Post Number: 8693 Registered: Oct-05
Thursday, January 04, 2007 - 03:56 GMT birthsheet on my friend's amp said 1190 at 14.4v so yes it is very underrated.
Post Number: 2040 Registered: Nov-05
Thursday, January 04, 2007 - 04:07 GMT chad what would you go with for two l5's 1000.1 or the 1500.1 i think id go with the 1500.1 just so id have that extra power if i ever wanted it
Post Number: 8695 Registered: Oct-05
Thursday, January 04, 2007 - 04:20 GMT i would too. i always support overpowering the subs.
Username: Skibum12189 Post Number: 16 Registered: Mar-06
Thursday, January 04, 2007 - 20:41 GMT Definitely go with the 1000.1 because the ZX series and most kicker amps push out about 15-20% more than advertised. If it's pushing 1200 watts to your L5's thats a perfect match because I believe they're 600 rms each.
Username: Skibum12189 Post Number: 17 Registered: Mar-06
Thursday, January 04, 2007 - 20:42 GMT Double check they're the 2 ohm version because ZX series amps are 2 ohm stable, not 1 ohm.
Username: Streetridersr22 Mason city,
Iowa
U.S.
Post Number: 37 Registered: Dec-06
Thursday, January 04, 2007 - 20:50 GMT spend the extra $$$ and get the 1500.1 yea ur over powering but u can turn it down and if u ever upgrade u have that power to....
Post Number: 2045 Registered: Nov-05
Thursday, January 04, 2007 - 22:07 GMT yepppppppppp ^
Username: Tjmutlow Post Number: 3439 Registered: Sep-05
Friday, January 05, 2007 - 22:54 GMT all that is pointless if he does not have the dual 2 ohm sub
