Silver Member Username: ShortysetniesRock Vegas, NC US Post Number: 916 Registered: Mar-06 | OK when I try and open certain folders I get an error message that looks like this: The way it tells me to change it wont work. When it tells me to browse for the folder to add (so this problem wont happen when I select that folder) it gives me the same box. Any suggestions? |
Platinum Member Username: Project6Post Number: 12459 Registered: Dec-03 | When was the last time you ran a virus scan? |
Gold Member Username: LeewXXXX!!WWWW, Yokosuka, ... Holla Back Y... Post Number: 1310 Registered: Jan-06 | SYMPTOMS When you run a program in Microsoft Windows XP Service Pack 2 (SP2) or in Windows XP Tablet PC Edition 2005, you may receive an error message that is similar to the following: Data Execution Prevention -- Microsoft Windows To help protect your computer, Windows has closed this program. Name: program name Publisher: program publisher Data Execution Prevention helps protect against damage from viruses or other threats. Some programs might not run correctly when it is turned on. For an updated version of this program, contact the publisher. What else should I do? If you click Close Message, the program quits, and Windows Error Reporting gives you the option to send an error report. Back to the top CAUSE This behavior occurs because Microsoft Windows XP SP2 uses the Data Execution Prevention (DEP) feature to help prevent damage from viruses and from other security threats. DEP works alone or with compatible microprocessors to mark some memory locations as "non-executable." If a program tries to run code from a protected location, DEP closes the program and notifies you, whether the code is malicious or not. Back to the top RESOLUTION To avoid this behavior, contact your program vendor to see if an update is available that enables the program to work correctly with DEP. Back to the top WORKAROUND If your computer is set to apply DEP to all programs and services, the DEP error message will have a Change Settings button. If an update to the program is not available, follow these steps to add an exception for the program from the DEP error message: 1. When you receive the error message that is mentioned in the "Symptoms" section, click Change Settings. 2. Click to select the check box next to the program, and then click Apply. 3. When you are prompted to restart your computer, click OK two times, and then restart your system. You can also add an exception for the program by using System Properties in Control Panel. To do this, follow these steps:1. Click Start, click Run, type sysdm.cpl, and then click OK. 2. Click the Advanced tab, click Performance, and then click Settings. 3. In Performance Options, click the Data Execution Prevention tab, and then click Add. 4. In the Open dialog box, locate and then click the program. 5. Click Open, click Apply, and then click OK. When you are prompted to restart your computer, click OK. Back to the top STATUS This behavior is by design. Back to the top MORE INFORMATION If your computer is configured to turn on DEP for essential Windows programs and services only, the Change Settings button will not be available from the DEP error message. You can view the DEP configuration for your computer in System in Control Panel. To do this, follow these steps:1. Click Start, click Run, type sysdm.cpl, and then click OK. 2. Click the Advanced tab, and then under Performance, click Settings. 3. In the Performance Options dialog box, click the Data Execution Prevention tab. 4. Note if Turn on DEP for essential Windows programs and services only or Turn on DEP for all programs and services except those I select: is selected. When your computer is configured to turn on DEP for essential Windows programs and services only, you cannot add an exception for a program. This is the behavior that is by design in Windows XP SP2. If your computer is configured to turn on DEP for essential Windows programs and services only, and the DEP error message continues to appear, a program may be installed that extends Windows functionality. This program may be installed so that it causes a DEP problem in an important Windows program or service. If this behavior is recent and has not occurred before, you may be able to prevent the DEP error message by removing recently installed programs. Back to the top REFERENCES For additional information about the DEP feature in Windows XP Service Pack 2, click the following article number to view the article in the Microsoft Knowledge Base: 875352 (http://support.microsoft.com/kb/875352/) A detailed description of the Data Execution Prevention feature in Windows XP Service Pack 2 |
Platinum Member Username: Project6Post Number: 12460 Registered: Dec-03 | There, you go...Jennifer just did the Google search for you Did you find that on the Microsoft website? |
Silver Member Username: Arande2400dB could probably d..., SouthWest Mi... Too Many DBs... Post Number: 831 Registered: Dec-06 | Did your computer stand up just start yelling at you for no reason? Dude no wonder it's pissin you off. |
Gold Member Username: MixneffectOrangevale, Ca. USA Post Number: 1407 Registered: Apr-05 | Next time stay away from p orn sites. |
Gold Member Username: LeewXXXX!!WWWW, Yokosuka, ... Holla Back Y... Post Number: 1311 Registered: Jan-06 | |
Silver Member Username: Arande2400dB could probably d..., SouthWest Mi... Too Many DBs... Post Number: 834 Registered: Dec-06 | Ah! I can't read that! |
Silver Member Username: ShortysetniesRock Vegas, NC US Post Number: 917 Registered: Mar-06 | I tried what jen said and it wont work either. When I try to add the folders I want to add it gives me this: If I take it back to circuit city will they be able to fix it? |
Gold Member Username: LeewXXXX!!WWWW, Yokosuka, ... Holla Back Y... Post Number: 1312 Registered: Jan-06 | well Andrew, you got problem with the registry and (or) DLL library! You need to find a special program to fix the registry and DLL library! Use google for that...just tape it "Fix Dll Library" or "RUNDLL ERORR" and still There is no guarantee that the program will fix your comp for 100% !!! you can make copy of all yours files to some hard drive and re-install windows. After that, you have to visit the Microsoft Web site to get all updates! |
Silver Member Username: Arande2400dB could probably d..., SouthWest Mi... Too Many DBs... Post Number: 864 Registered: Dec-06 | It's no surprise that she's right! |
Silver Member Username: ShortysetniesRock Vegas, NC US Post Number: 921 Registered: Mar-06 | i appreciate the help. I'm going to do that when I get home. thanks a lot |
Gold Member Username: LeewXXXX!!WWWW, Yokosuka, ... Holla Back Y... Post Number: 1313 Registered: Jan-06 | It's looks like your comp drive by the AMD Athlon and this the DLL file which one is corrupted: ntdll.dll try to update this file before you do something else! Do you remember when it happening? Maybe you installed some software? Or delete something? There is conflict in the system! check this out : http://www.dll-files.com/dllindex/dll-files.shtml?ntdll |
Gold Member Username: Nyyfan13Fi SSD USA Post Number: 2601 Registered: Jul-06 | jen > CC |
Silver Member Username: The_image_dynamicSan Diego Post Number: 184 Registered: Dec-06 | Andrew I told you the exact same thing a week ago on Jd. |
Silver Member Username: ShortysetniesRock Vegas, NC US Post Number: 925 Registered: Mar-06 | yeah I know. i was seein if anyone else had any other ideas. i just told jen thanks b/c she took her time. so as of now. nothing. I downloaded a torrent manager but I CAN'T find where it is saved on the computer and when I go into the control panel to try and delete it it doesn't show up in the "add/remove programs" folder. I'm lost |
Gold Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 1637 Registered: Jan-06 | EWW, I hate system32 errors. oh and if anyone on here cant fix it, go to www.techsupportforum.com they can help with almost anything |
Silver Member Username: Arande2400dB could probably d..., SouthWest Mi... Too Many DBs... Post Number: 868 Registered: Dec-06 | That is one of the meanest computers in the world. |
Silver Member Username: Motomattic3Post Number: 462 Registered: Oct-06 | can't you just do a system restore point? xp backs up your computer every month or so and you can choose when it wasn't giving you problems it keeps everything that you have installed, basically just going back to the restore piont. to access restore points go to start/run/ and type msconfig right above ok there should be a button that says launch system restore. once you click it a screen pops up that says restore my computer to an earlier time,click next and there will be a calander aprox 3months back or more select the date that your computer was runnin fine then let it work its magic. then walla! best torrent program=bitlord torrent look up sites: www.phazeddl.com (mostly rapidshare files) www.torrentreactor.net (actual torrents) |
Silver Member Username: ShortysetniesRock Vegas, NC US Post Number: 927 Registered: Mar-06 | d@mn. i was comin here to say I did a system restore but you already posted it kyle but yeah that worked. thanks for all the help |
