Fortec star key dish network HELP i need the keys!!!
Username: Star_star
Can someone gimme the fortec star (dish network) latest keys?
and wha}}t i deleted all the channels then when i put the key in will they come bak or will i have to search for them?
Username: Heyhowru2004
Post Number: 30
Active
4B 02 88 B1 CD 63 21 D1 A8 A5 3A C8 10 58 F4 C2
50 D9 06 47 5B 8F D0 2B A7 ED 67 C3 10 85 1A 11
Username: Star_star
kk ty i will try them and wht about my second question? (i deleted all the channels then when i put the key in will they come bak or will i have to search for them?)
Post Number: 31
no u have to do a blind scan again...autoroll is working again so turn on the autroll option
Username: Ciberofimatica
how can i put the key on Fortec Star Life time ultra i can find right place o screen...
Please Help me...
Username: Prfrmnj
Post Number: 1167
You are better off loading bin 287t and not having to worry about inputting keys. Go to the thread "List of Reputable DSS Sites" and pick any one and go get the bin after you register for free. These are the sites recommended by all Senior Members here and you will not run the risk of having your IP address exposed or getting garbage files. You will also find detailed instructions on how to flash your receiver.
