New member Username: BlakkPost Number: 1 Registered: Jan-07 | I have 2 planet audio big band 15's, there are 4 channels behind the woofers, how do i wire them to get the most out of them with a power acoustic 2400 amp |
Gold Member Username: PelonaPerres, California Post Number: 1951 Registered: Dec-05 | i suggest new subs and amp |
New member Username: BlakkPost Number: 2 Registered: Jan-07 | Why new subs and amp, nothing is wrong with them |
Gold Member Username: Killerzracing71Fredericksburg, Virginia United states Post Number: 1202 Registered: Aug-05 | hes tryin to b funny cuz most people have higher end stuff... whuts the voice coil configuration on the subs dual 4 ohm dual 2 ohm single 2 or single 4 ohm n whut r the specs on the amp |
New member Username: BlakkPost Number: 3 Registered: Jan-07 | amp specs- A2400DB 1ch 900@4ohm 1400@2ohm 1800RMS 2400max subs- Dual 2ohms |
Silver Member Username: Teddy21Ann Arbor, MI USA Post Number: 357 Registered: Feb-06 | go to http://www.rockfordfosgate.com/rftech/woofer_wizard.asp this will show you diagrams on how to wire them I dont think that you can wire to 2 0hms so the most your are gonna get outta that amp is 450 watts per sub wired to 4 ohm. |
