I have a Curtis 5.1 surround sound w/subwoofer hooking into a rca dvd recorder and a hitashi hd tv. sound only comes from the center speaker. any suggestions?
400dB could probably d...,
4000 isnt ev...
100,000dB FU...
Post Number: 404 Registered: Dec-06
Make sure your surround receiver is set up to output sound to all the speakers. Otherwise, it's probably a little thing you overlooked, which is usually the cause.
it is an analog cord that is connecting to the dvd player. my problem is that there is 2 wires coming out of the dvd player, and i need 6 to plug into the sub.
the manual is no help. all it is a picture of the back of the sub with lines going to it. but the lines all connect so it is difficult to read. plus this is a curtis brand we are talking about.
they are color coded for the speakers, but all the other connections are white and red. there is 5 outputs for the speakers and 6 inputs for the dvd sound. when i have the 2 lines(1 red and 1 white) plugged into the sub woofer, i get sound from 2 speakers. when i change the plugs and i get sound from the 2 other speakers. i do think that it is the dvd player and not having enough ports to plug in. but thats just me.
I was hoping that i would be able to get it to work by rigging it some way, i guess i will have to go get a 5.1 dvd player. thanks for all your help, it was great.
