Bronze Member Username: ThemannMt. Holly, NC USA Post Number: 62 Registered: Jan-06 | What is the website that shows you how to wire subs down to like 2 or 1 ohms? or can I wire 2 cvr12 2 ohm subs down to 1 ohm? |
Gold Member Username: Nyyfan13Fi SSD USA Post Number: 2082 Registered: Jul-06 | http://www.the12volt.com/caraudio/woofer_configurations.asp |
Silver Member Username: Devastation101Audioque SD2.5-ville, HENDERSON, NC US of A Post Number: 765 Registered: Feb-06 | no you can't do that. 2 ohm, .5 ohm |
Silver Member Username: Devastation101Audioque SD2.5-ville, HENDERSON, NC US of A Post Number: 766 Registered: Feb-06 | there ya go Yanks! |
Gold Member Username: Nyyfan13Fi SSD USA Post Number: 2083 Registered: Jul-06 | yep, i squeked my post in right before you but yea i hope they arent 2 dual 2 ohms subs cause u cant get one ohm, like trell said, .5 or 2 ohm |
Bronze Member Username: ThemannMt. Holly, NC USA Post Number: 63 Registered: Jan-06 | Thank you, and no they arent 2 dual 2 ohms, I'm helping a friend buy some subs and wanted to make sure I didn't make him get the wrong thing |
Silver Member Username: Devastation101Audioque SD2.5-ville, HENDERSON, NC US of A Post Number: 769 Registered: Feb-06 | Cool, if he's getting a 2 sub setup, I would stick with a 4 ohm DVC. Most people I know wire these types of setups in 1 ohm with a stable amp. Got it? |
Bronze Member Username: Skibum12189Post Number: 42 Registered: Mar-06 | Are most amps .5 ohm stable. When I was looking to buy they never advertised it like that? Just wondering.... |
Silver Member Username: Devastation101Audioque SD2.5-ville, HENDERSON, NC US of A Post Number: 770 Registered: Feb-06 | I think it's kinda hard to find an amp that is.5 ohm stable! |
Gold Member Username: BlainewAlpine type S 6.5 inch... Post Number: 2077 Registered: Nov-05 | if the are single 2 ohms you can get them to 1 ohm |
Bronze Member Username: ThemannMt. Holly, NC USA Post Number: 64 Registered: Jan-06 | I have two cvr12s 4 ohm wired to 2 ohm powered by a kicker 600.1 and then another cvr on a rf301m. I'm going to sell him my rf just so he can start bumping and I was going to wire his two cvrs he just bought to 2 ohm up to the rf that is 300rms at 2 ohm, does that make any sense and will that work? lol |
Silver Member Username: Devastation101Audioque SD2.5-ville, HENDERSON, NC US of A Post Number: 777 Registered: Feb-06 | Wait so you're saying that right now you have two different amps on each of your CVRs? If so, I really don't think that's a good idea! |
Bronze Member Username: ThemannMt. Holly, NC USA Post Number: 65 Registered: Jan-06 | no, I have 3 cvrs. Two on the 600.1 and one on the rf. |
