Rattling!!!!
Username: Camarobump
Post Number: 76
Hey my camaro rattles like crazy. It sounds like the hatch is rattling bad, but there are rattles that i can't really tell where they're coming from. It would sound so much better without that rattling. How do I fix this?
Username: Andrew571
Post Number: 546
well, the most practical way would be sound deadener...
however look around while it playing and see whats rattling, alotta times its simple things like license plate, door handles, speaker wires in ur panels vibrating against the metal inside (big one, i wrapped foam stuff around my wires)
also make sure all of your panels are secured in, also ur jack might be vibrating against something if it isnt secured properly in its compartment
Username: Oglejust
RE SX, USA, Il
Post Number: 679
get some dynamat or edead or some peal n seal
