Make Sealed box Ported
Username: Malizeryan
Hey. I just got a 13w7 and a 1000/1 in a sealed prowedge jl box. Its really not as loud as i thought it would be. I think a ported box would be alot louder than this sealed one, but it costed me alot of money. Could i just drill out a 4" hole in the side and it would be technically ported? would this be a bad idea?
Username: Logan__tille
Orion 1200D For Sale, Hit me up
Post Number: 4145
I would just keep it the way it is. Im am not impressed with the W7s either. I would sell it and get something else.
Username: 54danny54
KY More Wang Th...
Post Number: 3173
lol if you just cut a 4 inch hole in the side it will be tuned to god knows wat.
it will be much easier to make your own ported box.
www.subwoofertools.com/ported-box
Fi Audio BTL
Post Number: 8618
you can cut a hole and stick a pvc pipe in there. you would have to calculate your desired tuning and cut the pipe accordingly.
but i would just build another box.
Post Number: 4154
Only 1 4 inch? I think it will wistle like hell. A lot of port noise.
