Healthy screws...
Username: Tremor1127
Post Number: 626
are there any special screws or bolts or anything to use for subwoofers in high spl setups?
Fi Audio BTL
Post Number: 8575
use these with some bolts.
Username: Adddisorder
West palm, Florida
Post Number: 2614
chad i know this is dumbass hell but what are those called. im buying some in the next day or two and was wondering
Username: Logan__tille
Orion 1200D For Sale, Hit me up
Post Number: 4124
Username: Crayola0
Wisconsin
Post Number: 1566
they are called like T-nuts or sumthin like that
Fi Audio BTL
Post Number: 8576
jaymes is right.
Nj US
Post Number: 2475
http://www.fastenersuperstore.com/stores/superstore/step3.cfm?category=Nuts&prod uctCategory=Tee%20Nuts&stage=step3&gclid=CIqrhvLhwIkCFRhFVAod_2kuPg
Nj US
Post Number: 2476
Good one James!!!
Post Number: 627
yeah, they are t nuts, ive never used them, dont know how to. i will pick some up and master them. i was just always skeptical about them, but they must stay in the wood once there, eh?
Post Number: 628
do you drill a hole and hammer them in the hole?
Post Number: 629
my first real system was all built for me and it was 3 of the first 15" L7s, t nuts were used but i never knew how he put them in...
Fi Audio BTL
Post Number: 8578
drill a hole and hammer them in on the other side of the wood. meaning from the inside the box hammer the t nuts in.
Username: The_image_dynamic
San Diego
Post Number: 84
...and put some wood glue on them, making sure not to get any in the threads. It s*cks having one spin out on you when trying to take your sub out. MDF is not the best wood for those little spikes to hold onto.
Fi Audio BTL
Post Number: 8585
yeah i hate it when you are on your last bolt and you hear a clank. the damn t nut fell off so i had to take out the sub again to fix that.
