New member Username: SmokeyjudithPost Number: 1 Registered: Dec-06 | yeah it wont turn off and ive done evrything they say w/ how to reset it but it dont work please help me i want to turn it off cause i dont wanna kill the battery.... |
Silver Member Username: DkchillinVermont Post Number: 355 Registered: Mar-05 | If you've followed the steps below and it still won't shut off then I'm not sure what else you can do. To reset your iPod nano: Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. |
New member Username: SmokeyjudithPost Number: 3 Registered: Dec-06 | Thank U sooooo much it worked my ipod turns off again on the apple web site it tells u the wrong way of how u reset it... thank again!!!![]() |
Silver Member Username: DkchillinVermont Post Number: 356 Registered: Mar-05 | Judith, you're very welcome. I'm not sure what page you were looking at on the Apple site, but those instructions are from their support section. If you have problems in the future you can reference it here. |
