Taking Stab at First Box Next Weekend, Got Any Pointers
Username: Freezeman_7
FI SSD, OK U.S.A
Post Number: 564
let me know, fit two twelves.. lil nervous... lol
Username: Van_man
Boston South, MA
Post Number: 1624
Measure twice, cut once.
Username: Drsmith
Montana USA
Post Number: 2401
make it 3 times lol can never be to careful, depending on what subs and how much power you might want to brace the inside and what not
Fi Audio BTL
Post Number: 8753
good luck and may the force be with you.
as far as the advice goes, looks like marc and doktah has it covered.
Username: Safe_cracker
Chicago, IL US
Post Number: 2318
When cutting MDF wear a breathing aparatis and eye protection. MDF contains urea and formeldehyde which is a carcynogen (sp), dam it causes cancer, lol. Polo.. :-O
Username: Greeney1888
Maple Grove, MN United States
Post Number: 258
when drawing circles for the sub, get a wood 12in ruler. hammer and nail through the ruler into the wood at 1 inch and then make another hole however big u want ur circle and stick your pencil through the other hole and u got your perfect circle. cant get any easier
Fi Audio BTL
Post Number: 8756
wear gloves when you are applying the glue.
Username: Mvplefty12
Pinellas, FLA America
Post Number: 473
Predrill!!!! I split so much wood on my first box lol
Username: Rovin
1 12 Premier...
Post Number: 10325
all u need 2 know is here :
http://www.diysubwoofers.org/ .........
Username: Nyyfan13
Fi SSD USA
Post Number: 2051
good luck, its not too hard. predrill the holes is a biggie, i didnt do that on one piece and split the b!tch are over, obviously didnt use that piece.
Username: Southernrebel
Post Number: 4010
won) if the blade is dull on your table/skil saw...change it right then! A sharp blade is alot less likly to kick back on you...i dam near took a hand off using a dull blade bout a year ago.
tew) dont cut the $h^t out of yourself :-)
threave) Use woodglue on ALL joints, caulk the inside...some say use liquid nails but i have found that over time it gets kinda flaky.
fo) if using a skil-saw instead of a table saw, make sure you build yourself a gate to keep your cuts staight.
fo-n-a-haf) have a buddy help...it will go alot faster and save alot of trouble holding stuff in place.
bout 5) make sure you draw up a cut-sheet before you start...it will save you alot of time on rethinking cuts.
Username: Blainew
Alpine type S 6.5 inch...
Post Number: 2057
dont use a jigsaw...
Username: Tanmanfosho
C Bang, Hardcore Iowa USA
Post Number: 288
dont fack up biggest advice...lol everyone already said the stuff. biggest though measure 3 tiems cut once
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 869
I use a jig to cut the holes for the woofers. works perfect...
Username: Andrew571
Post Number: 570
ill come down and help u buddy ;P
FI SSD, OK U.S.A
Post Number: 565
thanks for all the advice. im gonna be making a pretty basic box.
ha, ok andrizzle, it might be a couple weeks wen im able to walk again, cause of the ankle surgery, i no yall member my sh!t with that
Username: Blainew
Post Number: 2059
yeah jigsaw for holes...but thats it. i tried to make a box with ONLY a jigsaw and the pieces didnt fit together afterwards
Username: Mygame5982
Comp Vr H-TOWN, TEXAS US
Post Number: 952
take your time
i f'd ^^ so much stuff trying to rush
Username: Wolfman1966
WEST MONROE , LOUISIANA USA
Post Number: 1511
OH, james, you posting wh0re, i thought you weren't trying to go gold, but you keep right on posting in as many threads as you can...he he he, come on whats another hour, you're less than 50 posts from gold >which on here really doesn't mean a thing, ...now when we go Platinum....by then people will usually have learned something.....btw Platinum is 10k posts
Post Number: 960
wowwwwwwwwww...well if ecoustics is around long enough i could go for platinum.lol
Post Number: 1513
lot of people are going to that other place...you know the one, that begins with j?
Post Number: 964
ooooooooo mayne forget that place
i tried it for like a week..but couldnt log back in so i said forget it.lol
Username: Frkkevin
Post Number: 2422
welp.. everything is about covered
don't put any screws within 1-1/2 of the edge of the wood or it might split on ya :-)
and wood glue is your best friend when it comes to box building.. don't get cheap and use something else for the joints
