il tell it like it happened it fitted to my 96 fto
went to pull up outside my house and engine died power steering went and dials/insturments died ,lights stayed on and stereo stayed on went to start up again and nothing just struggling tried jump starting with another car still nothing left for 5 mins tried again and it started . went to reverse died again, got out went to leave car till weekend when its light , pressed alarm fob windows and mirrors never closed up(they do normally, full closure fitted) but doors locked so i unlocked it started again was fine turned off and alarmed again everything shut up like normal. so i guess i got an alarm fault well hoping thats it anyway.
i have a clifford concept G4 with all bells and whistles . have been reading about the internal battery failing if not chirps but mine still chirps. can anyone shed some light as i dont want to go round a round about and loose power again and end up in a railling somewhere.
sorry about bad grammer but its late and i need help thanks all.
iv got a sneaky feeling its the immoberliser part of the alarm cos it just wouldnt start and dials were dead . so hoping its a loose wire or fuse.just wodering if anyone else had a similar problem before i call out the auto electrician and get spanked
I have been out in it today and all seems fine but i want it fixed for safety cos its a bit dangerous
