Went ahead and installed the 5-1/4" mids to replace my 6-1/2" factory mids... Peal-n-Sealed the door..
.... and well idk what happened but when I rolled me window back down I heard a SNAP! .. rolled it up and it only went up 6 inches. They are electric so I was pissed cuz I thought I broke the mechanism. Well the window caught the wire and snapped it and I think the window caught the magnet on those suckas so the factory went back in. I'll be honest the factory mids suprised me... very well built for factory and everything was run with 14awg wiring. Not too shabby..
So after this mishap I'm am not doing any comps for a while.. although you guys might see me fiberglass some pods for some 7" daytons
....either or mold them into my door panels .... Weeeeeeeeeeeee!
I made an adapter lol... needless to say they are not in right now but oh well.. it was worth a shot. I can make them work but depending on if I get the 7" dayton comp set I won't worry about it.. if not I'll do it
i have done this a few times b4 so im thinking all u need r some risers/spacers to uplift them a bit so u get more room @ the back inside the door - ....
