Jensen VM9021TS ebrake bypass
Username: Twinkie
Haysville, Kansas United States
How do I bypass the pink ebrake wire so i can veiw videos while driving, there has to be a way to do this, even if it's illegal
Username: Way2smart
Post Number: 161
1) Insert the DVD and you'll get the blue screen.
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice(thats up up twice) and then click it once.
a hidden menu will come
This is what you want:
Region Code: 1
Brake Override ON
Macrovision: OFF
4) Press SYS SETUP on the main remote twice to save your settings.
It may take a few tries but you'll get it
best off luck
oo ya and no need to connect the pink wire anywhere
and it is illegal
cops see u heavy fine
