**FLI AMP AND 12" SUB WIRING PROBLEM**
Username: Xemoxcorex
I connected everything up first time fine and it was all working. i then re-wired everything to fit my car.
the sub/amp im using is a "Fli Trap" 12" 1000w sub with a monoamp "Loaded 250".
after the re-wiring it didnt work. the protection LED is constantly on. ive checked all fuses and wiring kit.
what else could be wrong?
cheers,
Carl
Sub And Amp Specs:
SUB:
Sub Size - 12"
RMS Power - 300w
Peak Power - 1000w
Sensitivity - 90db
Frequency Response - 20 - 15000hz
Impedance - 4ohms
AMP:
FLI Loaded 250 Monoamp
Username: Teddy21
Ann Arbor, MI USA
Post Number: 317
make sure your ground is very good, and it would probably help to just unhook everything and rewire the whole car...I mean since it worked just before, it should work fine now...
that way you know that you covered every possible problem
i done that today but still nothing is working.
i checked inside the sub box to see if the speaker wires had shorted but they're fine.
