New member Username: BrookstheproPost Number: 1 Registered: Feb-07 | sorry if this topic has been discussed previously but i joined and am posting on this site from my cellphone so bear with me :-). i have 2 12' subs in a box from my old car stereo. i want to hook it up to my harmon kardon reciever. i know i cant directly hook up the subs to the speaker out's on the reciever. and i know i cant use a car amplifier easily for my system...... now. if i were to buy this amplifier (DFX HDJ2000) and run rca cable from my reviever's sub built in crossover (sub woofer out) to the amplifier i want to get. will it work fine?....i wanna know it will work before i spend $200 on the amp. TIA!!! -brooks |
Platinum Member Username: Project6Post Number: 12760 Registered: Dec-03 | It will work. All you really need is a proper amplifier that can drive the speakers. |
New member Username: BrookstheproPost Number: 2 Registered: Feb-07 | is the hdj2000 not a proper amp for this setup? see link: http://www.hollywooddj.com/dfxhdj2000.html |
Platinum Member Username: Project6Post Number: 12773 Registered: Dec-03 | The amp can drive 4 ohm loads, just make sure that the speaker are rated at 4 Ohms. |
Silver Member Username: GamerdudeOntario Canada Post Number: 387 Registered: Apr-06 | Bryston if you have the money |
New member Username: BrookstheproPost Number: 3 Registered: Feb-07 | ya my speakers are at 4ohms |
Platinum Member Username: Project6Post Number: 12783 Registered: Dec-03 | Go for it and let us know how you like it. |
New member Username: BrookstheproPost Number: 4 Registered: Feb-07 | thanks alot for you input guys. i will let you know how i like the setup! |
