Need advice on amp
Username: Dddd
Fayettville, Tennessee Lincoln
Post Number: 14
I have 2 dvc memphis 15" subs.I want to put them in a center slot ported box.They are in a sealed box.My sony explode 1200 watt 1 channel isnt 1 ohm stable,but ive also got a SPL 1600 watt 4 channel amp it says its 2 ohm stable.Do you think this amp will work,and am i making the wright decesion by changing boxes.If the spl wont work what amp do you reccomend?
Username: James1115
Use a simple...
Post Number: 8367
are they dual 4 ohm? what is the rms on each sub?
Username: Dddd
Post Number: 16
they are dvc 4 ohm subs.i believe the rms is 800
