Use a Bose Acoustimass Speaker w a Computer?
Username: Bennyboy
Has anyone done this? I have an acoustimass 20 speaker system without the head unit and would like to drive the system with the audio out from my computer.
I have a few questions.
1. How do you turn on the amplifier?
2. What are the pinouts for the bose cable (ie which pins are the audio in)?
Username: Gavdawg
Post Number: 35
you should call bose and ask them this. because if it is powered, you may very well be able to do this.
1-800-444-2673 is the Bose phone number if you are a US resident
Username: Johansj
Sweden
I had the same question and got the ansvar from Bose that the system has signal sensing on the low-level input. That means that you just connect the PC to L&R on the AM 20 and your fine.
BR
Johan
Username: Arande2
400dB could probably d..., 4000 isnt ev... 100,000dB FU...
Post Number: 216
I was wanting to hook some speakers up to my computer and just ended up hooking it all straight into my home theater system. I just hooked the digital coaxial audio ouput to the input on my receiver. Then I hooked the S-video to my TV (pic quality is just fine). I'm very happy with this as the power of my home theater owns that of a cheap $200 computer speaker system.
