Kenwood Amps
Username: Scott_shumpert
Anderson, South Carolina United States
I have the 1700 watt Kenwood amp and it makes the sub click. i know i blew it but can it be fixed?
Username: Van_man
Boston South, MA
Post Number: 1540
please list model numbers of amp and sub more info the better
like Kenwood 9152 1700 watts
and sony 12 dvc4 10,000 watts
Its Kenwood KAC-9102D 1700 watts hooked up to two Power Acoustik Fubar 12's 1800 watts but the subs are ok.
Username: Van_man
Boston South, MA
Post Number: 1546
well that amp is only 2 ohm stable. Are the subs single coil 4? If so you probly fried the power supply running it down to 1 ohm.
Username: Van_man
Boston South, MA
Post Number: 1547
my bad, if single 4 coils it would be a 2 ohm load
Username: Van_man
Boston South, MA
Post Number: 1553
well that amp is only 2 ohm stable. Are the subs duel coil 4? If so you probly fried the power supply running it down to 1 ohm.
the subs are duel voice coil. i had them hooked up by a wire coming from the amp to one sub and another wire running from that sub to the other. would that cause the amp to blow and is there any way to fix it or should i just buy another one or buy a different amp(suggestion)?
also the amp light flickers and sub just clicks. no bass out of the sub what so ever.
Username: Shade
Moxee, Wa U.S.
Post Number: 41
regardless if the amp is still good or not, u should get a diff amp IMO. i made the mistake of gettin a kenwood...turned around 2 months and spent 350 on a diff amp...nice lil $550 lesson.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 3770
kenwood amps lack of quality. Bad power supply.
