Ported vs Sealed
Username: Arwlacrosse182
Post Number: 12
I am getting 2 12" typer R's in my 4runner. Sould i get a ported or Sealed box? What is the difference between the two?
Username: Bump05
We Stay Fly, 18 SX USA
Post Number: 636
id go ported 1.5-2 cube each tuned to 38hz
Username: Andrew571
Post Number: 484
ported, sounds better louder deeper.
sealed, not as much of each things ported does - for type Rs, i would only go sealed if there was a room issue. PORTED FTW
Username: Suleman36
Post Number: 4154
ok first, you need to determine what the speakers are made for.. not all drivers work in both box types.
you need the TS stats 9should come with the subs, or download the tech specs from their website)
and calculate the EBP
here's how:
Efficiency Bandwidth Product (EBP)
EBP = Fs / Qes
50 or less = best used in a sealed enclosure.
50 - 90 = flexible enclosure options.
90 or greater = best used in ported enclosure.
very simple calculation.
Username: Trey4sports
Post Number: 196
hey mo i was just wandering, if a sub is rate at say 48, does that mean there is a smaller gap in loudness going from sealed to ported in that driver whereas if you go from sealed to ported with a driver thats 115 there is a much bigger gap?
Username: Mvplefty12
Pinellas, FLA America
Post Number: 408
Alex... You should do 1 15" Type R in the 4 runner... I know a guy doing 142.1 db with a 15" R in the trunk of his car. Definatly port whatever you get though... The 12"s I'd tune them more around 34hz then 38, the 15" I'd do 32hz
Username: Suleman36
Post Number: 4155
for the 12" subs, go with about 1.5cu ft per sub for sealed, and 2cu ft per sub if ported.
ported, tune the ports to about 35Hz, using 4" inner diameter ports. (tuning the ports is done by adjusting their length. Remember to allow for speaker (and port tube volume) displacement when calculating the box dimensions for interior volume.
3cu ft per 15" sub, 6" inner diameter ports, one per chamber.
Username: Basshead86
FTW
Post Number: 9656
MO and the EBP FTW
