Stereo wont go on
Username: Blazrg
Warren, Ri Us
i took it out of my g/f car to put in mine and when i went to put it back in it wouldnt work,all the wires correct.the only way it goes on is when i put the acc wire with the power wire but then when i turn the key off the stations erase. plz help
Username: Tjmutlow
Post Number: 3390
then there is a problem, most likely with the fuse in the fuse panle if your not getting any switched power.
Username: Logan__tille
RE XXXYeah its 15 ...
Post Number: 3591
yea, check all the fuses, and the fuse in the HU. Is it gounded correctly?
