Ultrastar 5000
Username: Arvalan
Post Number: 13
please help me to get the loader for this receiver
Username: Albino_midget
Post Number: 352
2k232-- search at hashhu dot com
Username: Arvalan
Post Number: 14
please, what is the last file name wich is working now?
Post Number: 362
don't know if there is a working bin, the ultrastar 5000 needs spacestar S/W
go to www.dvbspider.tk or other site www.solutioncode.com(though i can't find much info)
Username: Elmer_gantry
Parsons, Tn. Usa
If spacestar dvd 500 bin will work, spider came out with 6.9d beta last month .Works, don't autoroll,you can find it at Curious Contraptions Community, or FTAPirate.com
Username: Arvalan
Post Number: 15
already, i treid 6.9d beta. but it wont work for me
Post Number: 366
c/p from solutioncode
Remember the key order is flipped F key first then th E key second, this might be your problem.......
Username: Arvalan
Post Number: 16
hi Albino Midget, are you mean 00=F and 01=E ? my keys order, already F first then E second. also, the name of the provider is idea dish (dosen't say dishnetwork) and ID is 0001 instead of 0101
Post Number: 373
arvalan.a, from what i read -yes 00=F,01=E, the provider ID should be 0101. thats all my knowledge of the ultrastar. i would search further in the sites listed in this thread.--good luck
