Help 2 choose
Username: Ztx
Post Number: 12
hi
i am looking for 4 round speakers 6''-7'' to fit landrover freelander 3 doors 2001 reg., 4 tweeters, 2 subs, 2 amps for them and a capacitor. Speakers 100W RMS or more, good tweeters (offer), subs 250W RMS each or more and 1 amp (is that monoblock what's the best choise?) for subs and 1 amp (4 channels?) for speakers&tweeters...
best thing would be 1 brand for everything
dont know much about so would be thanful for any help, offers and ideas.
also looking for head unit
if any1 has any offers, let me know, would buy
Username: Ztx
Post Number: 13
also tell me smthg about components...
Username: Carguy
Post Number: 5810
For your component speakers try this link.
On eBay type this number on the search window.
eBay item no - 280061022358
That'll display Infinity Kappa Perfect 6.5" set. They ship to worldwide, so you shouldn't have any problem.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 3764
forget about capacitors if you don't have a HO alt
Username: Ztx
Post Number: 14
what is HO alt????? why forget about capacitors? i've got one already in my car
Username: Ztx
Post Number: 15
so i shall go for infinity set? comps subs amps?
why forget about power caps? what is HO alt?
and what about HU ? which one would u offer?
Username: Tjmutlow
Post Number: 3377
Memphis, how much do you want to spend, I will see what i can get it to you delivered.
Username: Tjmutlow
Post Number: 3378
it looks like I can get you a whole memphis setup, subs, 5 channel, 2 sets components,ported box,amp kit for $955 deliverd with warranty, as far as cap you can get one cheaper then memphis that will do the same, but i would go with an Batcap 400 from exstatic.
Username: Ztx
Post Number: 16
i was thinking around your predicted amount. the thing is that i am in uk, how much would delivery cost? tell me more about that memphis set... powers RMS, amps details...
thanks ty mutlow
ps and head unit? any ideas?
