Bronze Member Username: Camarobump
Post Number: 56 Registered: Sep-06
Posted on What amp should i purchase for 2 DA9012 subs? They are 1100w rms a piece. |
Gold Member Username: Juliob
Santo DomingoDominican Re...
Post Number: 3722 Registered: Dec-05
Posted on voice coil config please |
Post Number: 57 Registered: Sep-06
Posted on dual 4 ohms, or 2ohms and 8ohms operation |
Silver Member Username: Sinful_systems70
Post Number: 174 Registered: Nov-06
Posted on Just so you know (2)dual 4 ohm subs wire to 1 or 4 ohms if you plan to run the two subs with one amp. |
New member Username: Kelldd
Vancouver,
B.C
Post Number: 1 Registered: Dec-06
Posted on im new here ..... how do u make your own post eny one hellp me ... |
Post Number: 3741 Registered: Dec-05
Posted on if they're really 1100w rms a piece you need a 2000-2200w rms amp at 1 ohm Tell us a budget to work with |
