Here is the problem I'm having. When I have it at low or high volume the head unit turns off. I have tried turning off the epicenter still turns off. The brain is underneath the carpet not too sure if it's getting hot. Advice on getting this problem resolve? Could it be a connection?
well with the car on voltage should be above 12.5v and with the car off it should be 12.5v so i was thinking maybe your HU is shutting off becasue of either low voltage or really high voltage so id moniter that for a while
