Silver Member Username: Freezeman_7FI SSD, OK U.S.A Post Number: 537 Registered: May-06 | i have some kappa 5x7's 100wrms each, and they jus aint loud enough, i have an 04 f150, and need sum more high and mid bass, my subs are drowin out the music, and the subs are down, what do anyone have in mind as for FOUR (4) new 5x7's want to spend about a thousand all together! |
Bronze Member Username: The_image_dynamicSan Diego Post Number: 31 Registered: Dec-06 | Seems to me that your truck takes 6x8's? You're not going to get much louder if you use a standard 6x8 speaker. You could get a conversion plate and put a high quality 5 1/4" in there and then mount the tweets on your door or somewhere. That or mod it out a little and go with 6 1/2 comps instead. |
Gold Member Username: MixneffectOrangevale, Ca. USA Post Number: 1305 Registered: Apr-05 | https://www.ecoustics.com/electronics/forum/car-audio/305376.html |
Bronze Member Username: The_image_dynamicSan Diego Post Number: 33 Registered: Dec-06 | sorry mix I didn't see that he double-posted |
