I had just recently rearranged my living room moving the TV and my Pansat 2700a to a differnet loaction. my pansat was working fine before i moved it but because i disconnected it then reconnect it must have lost the signal or something (which is very wierd).. i cant seem to get a signal at all and when i go into antenna set up most thigns are either off or disabled.. can anyone just help me out as to how i can get my signal back? i dont think i actually have to reposition my satellite. THank you in advance
Make shure the output channel switch,[whitch is a very tiny slide switch by the coax connections is on channel 3] sometimes you can unknowingly touch and move it when connecting/disconnecting the cables.Then switch on/off the reset toggole switch and watch tv.
