Need Matching AMP FOR KICKER L7
Username: Ars88
Post Number: 119
hey guys i need a really really good amp for my 12 inch kicker l7....my budget is 200bux shipped...some1 plz gimme an amp model
i was think with a hifonics 1000watt amp but not sure exactly that will fit my budget so maybe any1 here can point me to a site where it will.
thx alot
Username: Dsmith07
LaGrange, NC US oF A
Post Number: 283
get some more money...IMO
Username: Logan__tille
RE XXXYeah its 15 ...
Post Number: 3199
yea^^^
Username: Ars88
Post Number: 120
lol ok.....300 bux maybe somethin now?
Username: Devastation101
Audioque SD2.5-ville, HENDERSON, NC US of A
Post Number: 485
add 50 more and get an eD nine.1 or get Kevin's RECoil amp.
Post Number: 486
https://www.ecoustics.com/electronics/forum/car-audio/298591.html
Here ya go buddy!
Username: Frkkevin
Post Number: 2134
^^ .. Great amp .. ran on factory charging system and put up good numbers with a single 15.. 145.3dB
Username: Ars88
Post Number: 121
ok...thx but its 300 plus shippin
lol
thts still too much i guess i gotta wait a bit more...i needed an amp kid and all so thats why my budget is a bit low right now....
any1 think i might need to dynamat my trunk? i have an 00 impala...
Username: Ars88
Post Number: 122
amp kit***
Username: Ars88
Post Number: 123
some1 tell me if this is good.....
http://cgi.ebay.com/HIFONICS-BRUTUS-BX1000D-20th-Anniversary-Bass-Amp-1000w_W0QQ itemZ270065887013QQihZ017QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Ars88
Post Number: 124
guys..when they say 1000w at 1 ohm....
that mean when connected with 0/1 gauge wiring?
sry if thats a newb question but i wanna b sure
thx
Post Number: 487
nah, the ohm refers to the impendance the subwoofer is wired to. If that makes any sense...someone clear that up for me! lol
Username: Ars88
Post Number: 128
ya plz some1 make it clear to me on the wiring process...also is wiring monoblock amp different than other 2channel 4channel amps?
Username: Robman0079
Post Number: 142
L7- dual 4 ohm is gonna be wired to 2 ohms buddy, unless you get a dual 2 ohm subwoofer, which will wire up to 1 ohm. and no its not any different. connect the two positives on the sub to the positive on the amp and do the same for the negatives
Username: Dsmith07
Post Number: 288
arslan, you dont have to get everything at one time....u could save a bit more and get that amp then worry about the amp kit ....i doubt people on the forum bought all their stuff at one time...im pretty sure it was piece by piece
Username: Ars88
Post Number: 139
1000 watts RMS @ 1 ohm
700 watts RMS @ 2 ohms
350 watts RMS @ 4 ohms
lol some1 please explain this to me a little bit more than robbie did
thx a lot robbie but im still in the learning process..i really hate to sound noobish but i beleive every1 went thru this stage sometime
thx for advice derek u r right
