I want everyones opinion on this
Username: Nyyfan13
Fi SSD USA
Post Number: 1380
system for a friend, under 300, NO higher.
combo's im looking at:
ascendant audio assassin 100
phoenix gold 400.1 150
knuconcepts wiring 50
total about 300
JL w3 (from ctmike) dont know how much yet
pg 400.1 150
knuconceptz wiring 50
total about 300 hopefully
Fi X 120
pg 400.1 150
wiring 50
total about 320
or the classic CC
http://www.circuitcity.com/ssm/Customer-reviews-for-Bazooka-Dual-10-Subs-300W-Am p-and-Enclosure-Package-EL10190PP/sem/rpsm/oid/150746/rpem/ccd/productDetailRevi ew.do#tabs
^^joke
and what other cheap/good subs am i missing?
Username: Nyyfan13
Fi SSD USA
Post Number: 1381
oh and which amp kit?
http://www.knukonceptz.com/productDetail.cfm?prodID=KOL-AK8
would that be legit?
or would i need 4 gauge?
http://www.knukonceptz.com/productDetail.cfm?prodID=KOL-AK4
im not familair with the whole wiring issues as yuo cna tell
Username: Bump05
We Stay Fly, 18 SX USA
Post Number: 491
I would go with the 4 gauge.
and imo i would go with the w3 setup.
Username: Dsmith07
LaGrange, NC US oF A
Post Number: 285
w3 FTW i dont even think you'd need 4 gague but i would get it in case he upgrades in the future
Username: Loc_out
Santa Ana, Ca
Post Number: 572
W3 and 4 gague in case we wants to upgrade later.
Username: Nyyfan13
Fi SSD USA
Post Number: 1382
well that went well. and i really doubt hes gonna upgrade at all, so would the 8 gauge work for the w3/any of the subs listed?
and thanks for the opinions
Username: Bump05
Post Number: 496
yeah the 8 will work fine. on a 600 watt amp perfectly. i just would run 4 wont hurt anything. run it to a crossover and throw 8 out to the amp. always there for the upgrade JUST IN CASE :-)
Username: Dsmith07
Post Number: 292
yea hes always gonna wanna get something different whether he does or not who knows but i'd get the 4 just in case
Username: Dsmith07
Post Number: 293
there might be some used ones on ebay just look..
just kidding.
Username: Scottyb
Largo, Fl
Post Number: 22
you said that you look at the "cc" (circuit city) web site at the bazookas. I wouldnt recommend those compared to the other subs that you listed. I work in car audio at cc and we dont sell many of those. I would go with one of the kickers. i know we have comp vr's 2 12's for $120(400wrms per sub) buy one get one free or 2 12" mtx 4500 (225wrms per sub) for $99. i would rather see you go with those over the bazooka.
Username: Dsmith07
Post Number: 294
lol disreguard the post about " there might be some used ones on ebay" thought i was in another thread but apparently i wasnt
Username: Denali_on_22s
Maryville, TN Us
Post Number: 672
W3s dont have great power handling. My friend has two hooked up to a 500/1 and at high volumes his sound like $h!t... They distort TERRIBLY and he's using a sealed box. i would go with the fi.X
Username: Scottyb
Largo, Fl
Post Number: 23
if your trying to get everything for under 300 jl's arent probably the way to go unless you are getting a really good deal on them. what kinda a car does your friend have and what is looking for in a system.
Username: Bump05
Post Number: 497
he said he might buy it used..soo he could get it under 300 and the w3's sound good at somewhat higher volume he's only putting 600 on it so it wont distort...as long as the box is good and everything it will sound nice
Username: Nyyfan13
Fi SSD USA
Post Number: 1388
he has a 1989(yr?) jeep wagoneer. hes got plenty of space. and for scottb, the CC thing was a joke, i wouldnt let him buy that, he was just looking at it and i told him i could find better for 300. and i think he'll prob go with the 4 gauge. i think its down to the X and the w3. i want him to get the x cause i wanna hear one of those for myself.
thanks
Username: Kballa422
Lexington, KY USA
Post Number: 18
I ran 2 12" w3's in my Jeep Grand Cherokee for awhile. It was a pretty good setup, after that i bought a 15" RE XXX, so there was no going back, but looking back, when I had the w3's i was satisfied, but now I could never run them again lol. Im about to run 2 15" SI Mags.
Username: Nyyfan13
Fi SSD USA
Post Number: 1392
d-mn, those mags will be awesome.
Username: Nyyfan13
Fi SSD USA
Post Number: 1414
bump for any opinions/suggestions.
Username: Cenus
Hicksville, Ohio
Post Number: 2626
imo i would go with the assassin, but other subs you might look into would crystal pro se, re re(if you can find them), lower eclipse AL models, and maybe even a AA atlas, just some suggestions.
Username: Nyyfan13
Fi SSD USA
Post Number: 1418
ill look into those dustin, thanks
