6 Channel Audio vs. Digital Connection
Username: Jaday
SC
Post Number: 41
So I know that there have been tons of discussions about quality comparisons between Optical and Digital Coax, but I was curious about comparing these connections to a 6-Channel output. Any thoughts or studies that you guys know of?
Username: John_s
Columbus, Ohio US
Post Number: 1217
The quality of the digital to analog conversion in the sending or receiving unit will determine which is best.
Username: Mccambley
BREEZY POINT, NY USA
Post Number: 312
Someone correct me but I thought the six anolog connections were used for SACD and DVD audio only. If you use the six anolog connections you will fed Dolby Digital 5.1 to the receiver? And if the answer is no then there is no comparision betwen anolog and digital.
Username: John_s
Columbus, Ohio US
Post Number: 1226
My universal player does feed DD 5.1 on its multi-channel surround analog outputs. The only reason I would want to hear a movie via those outputs is if I had reason to believe that this particular player does a better job of converting DD to analog than my receiver.
Yeah, well, maybe. Hey it's all analog when it hits your eardrums. :-)
