Edead install day 1
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 1563
Put down 3 layers of Edead on the front two doors yesterday...heres a few random pics.
Username: James1115
Use a simple...
Post Number: 8050
looks nice Jake
Username: Andrew571
Post Number: 383
thats whats up right there
Username: Cenus
Hicksville, Ohio
Post Number: 2617
nice, which version did you get, i gonna get some v1se for christmas.
Username: Adddisorder
West palm, Florida
Post Number: 2265
damn your a big fan of eD
St. Louis, MO
Post Number: 1564
its the v1s^2. it is extremely easy to put on. just make sure u have an exacto knife and a good roller. it took me about 3 hours to do all three layers but getting the doors off on mountaineers takes a good 20 min, so any other car should take closer to 2-21/2 hours.
i put the type S speakers back in and the rainbows out because im changing speaker amps...little change in sq to say the least.
part 2 of the install is 2 layers on the back doors, 4 layers on back hatch, and 2 layers under the box.
part 3 is the headliner.
part 4 (if i have enough left) A and B pillars.
Fi AudioBTL
Post Number: 7836
awesome jake. looks like you were busy. also looks like you got a lot of work ahead you. good luck with everything.
Username: Bernymac
Cambodian
Post Number: 1327
nicely done, so how many sqft did you get? It'll give me an idea if I got enough for my yukon =).
Username: Crayola0
Wisconsin
Post Number: 1527
kind of looks like duct tape..lol
St. Louis, MO
Post Number: 1565
i got 180sqft all together, and i used almost a full roll (30sqft) on the front doors. its about 5sqft per layer.
Username: Bernymac
Cambodian
Post Number: 1334
Actually I don't think I need to worry. I forgot that I bought edead v3. I'm doing all doors, thats 6 total, and then cargo area, sides and under the box. Headliner I'll have to see about that.
Username: Loudon
Post Number: 681
ed makes solid equipment ... nice job jake
