Scroll top line (RIGHT/LEFT arrow key) to EchoStar 7
LNB Power ON
LNB Type STANDARD (LEGACY LNB) or ("OCS-DPS for PRO LNB)
LNB Freq. 11250
22KHz OFF
TP Freq. 12224 (Use 2239 if 12224 doesn't show YELLOW signal strength bar--12224 is a Spot Beam TP
Search option ALL
DiSEqc 1.0 PORT 1
Motor OFF
"OK" to REGULAR scan the 119 TP's
When finished, note of how many TV and RADIO channels
"EXIT" and "YES" to Save.
Scroll top line (RIGHT/LEFT arrow key) to EchoStar 6, 8
LNB Power ON
LNB Freq. 11250
22KHz OFF
TP Freq. 12224 (or lowest number if 12224 not available)
Search option ALL
DiSEqc 1.0 PORT 2
"OK" to REGULAR scan the 110 TP's
When finished, note how many TV and RADIO channels
"EXIT" to the MAIN MENU.
You now have your ANTENNA SETUP for 119 and 110 and you have REGULAR SCANNED your channels in. Both Satellites should give you around 598 Channels and 135 Radio stations. This might differ because of your location and spot beam.
