Bronze Member Username: TinytruckDuluth, Ga US of A Post Number: 35 Registered: Oct-06 | hey ive got two sheets of plexiglass that are 4'x8' and i was wonderng if i could make either a subwoofer box out of it or would it be better to build a amplifier rack out of it? I've got 1 15" kicker L7 to go in a box, about how much air do i need to make it hit the hardest, and deepest? |
Silver Member Username: Tdawg30Ohio USA Post Number: 741 Registered: Jun-06 | how thick is it????? and if its not around half an inch thick I wouldnt bother. I would make a sweet amp rack then make some other stuff outta it. |
Bronze Member Username: TinytruckDuluth, Ga US of A Post Number: 39 Registered: Oct-06 | bump |
Bronze Member Username: TinytruckDuluth, Ga US of A Post Number: 40 Registered: Oct-06 | na i think its 1/4 inch but on the amp rack how could i join it all together? how would i bond it? screws glue, ive never used plexiglass before? could i double the thickness to 1/2 inch then start building? |
Bronze Member Username: TinytruckDuluth, Ga US of A Post Number: 41 Registered: Oct-06 | any ideas for the amp rack? its goin in a ford ranger. |
Silver Member Username: Tdawg30Ohio USA Post Number: 742 Registered: Jun-06 | shoot some pictures of where you want to put the amp rack then get back on and show us. also go to this forum and you can get lots of help there. the people are very knowledgable about custom fabrication with that sort of thing. www.fiberglassforums.com |
Silver Member Username: Andrew571Stillwater/Edmond, Oklahoma USA Post Number: 362 Registered: Oct-05 | i wish i had some plexi glass to mess with, just start putting it everywhere!!!!!!!!!!!!!!! |
