Silver Member Username: Pike11012w6v2s, Indianapolis... Post Number: 284 Registered: Oct-05 | I was at a local stereo shop and the guy told me if you want to get really low you have to go sealed???? |
Silver Member Username: Bump05We Stay Fly, 18 SX USA Post Number: 362 Registered: Aug-06 | na i say ported 27hz gets low low sealed hits a more punchier bass that gives more sq |
Silver Member Username: Pike11012w6v2s, Indianapolis... Post Number: 285 Registered: Oct-05 | I am kind of new to box making. Is it standard the more port area you have the lower the tuning goes? |
Silver Member Username: Bump05We Stay Fly, 18 SX USA Post Number: 364 Registered: Aug-06 | im not sure i understand... what sub? how big of a box can u make? and ill tell you |
Gold Member Username: RedlinerWilmington, Ma Post Number: 3337 Registered: Jun-05 | sealed plays a flatter tune then a ported box so it kinda depends on how u have your ported tuned if u know what i mean someone correct me if im wrong |
Gold Member Username: JakeyplaysbassSt. Louis, MO Post Number: 1557 Registered: Jul-05 | to me sealed sounds like a more controlled or constant sound. it completely depends on the sub in order to know what box will be best for it. |
Bronze Member Username: Gh0st_31FL USA Post Number: 69 Registered: May-06 | if you want it low, jsut get a ported box and tune it low |
Gold Member Username: Basshead86FTW Post Number: 9347 Registered: Aug-05 | here's the thing....the lower you tune a ported box, the less control the sub has at higher freq. so there are trade-offs. |
Gold Member Username: BestmankindFi AudioBTL Post Number: 7669 Registered: Oct-05 | hitting low really depends on the sub. some subs hit low really well while others don't. |
Gold Member Username: Basshead86FTW Post Number: 9372 Registered: Aug-05 | indeed it does Chad, good point. but if you want balanced output across the scale, and don't want to sacrifice "muddy" sound in the upper sub bass region, go sealed. imo |
Gold Member Username: Extrmndor3Im pushing i... And pushing ... Post Number: 2804 Registered: Feb-06 | ported and try to make round ports instead of flared for alil more good soundidn sound and port free noise. yeayyyyyy go ports. |
Gold Member Username: Extrmndor3Im pushing i... And pushing ... Post Number: 2805 Registered: Feb-06 | why not try both??? ask who made this set up he got both of them and it looks like he can hit the lows pretty good. once again Mr. Rob for all of ya . yay with these two set up forget about steve meades, they are gonna b@ng him like a noob. |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 2122 Registered: Jan-06 | "hitting low really depends on the sub. some subs hit low really well while others don't" Technically any sub can play a 1hz tone, not that hard to do but how much power is required to keep it in control is design dependant. Depending on size, shape and tune a ported enclosure has the potential to be LOUDER not deeper. A ported box may loose control at higher power levels due to the loss of acoustic suspension. Because a sealed box retains its acoustic suspension throughout its entire playing range that will allow it to play through a much more vast set of frequencies which would only be cut by subwoofer design limitations. I would say a sealed box will play lower but if the same sub in a box able to play equally low the ported box would be louder. Polo. |
Gold Member Username: Basshead86FTW Post Number: 9391 Registered: Aug-05 | ^^^^ j/k polo. |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 2131 Registered: Jan-06 | J/K Muddy Polo.. |
Bronze Member Username: TanmanfoshoC Bang, Hardcore Iowa USA Post Number: 30 Registered: Nov-06 | can anyone tell me what spl, and sq means <<<<noob |
Gold Member Username: J_baby15Kentucky Post Number: 1013 Registered: Feb-06 | sound pressure-spl, loudness sound quality-sq, how good it sounds. |
Bronze Member Username: TanmanfoshoC Bang, Hardcore Iowa USA Post Number: 34 Registered: Nov-06 | thank you |
Gold Member Username: Basshead86FTW Post Number: 9416 Registered: Aug-05 | lmao |
